Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 Problem
Thread: 700R4 Problem
Old 12-31-2011, 06:28 PM
revspan revspan is offline
Originally Posted by adantessr
The factory recommended adjustment of the 700R4 TV cable is as follows. Hold the throttle at wide open by what ever means available. Easiest to have somebody hold the go pedal to the floor. Depress the tab on the TV cable adjustment and tighten the cable until all the free travel is gone. I mean 'tight' . If it shifts too hard for your liking from 1st to 2nd, you can loosen the cable (very slightly), I mean, don't go more than 1/16" at a time. It is very sensitive. I attached the wiring diagram for manual control of the lockup converter. Don't forget to ground (pin D). It works fantastic great in my T-bucket. BTW Since neither you nor I are using a factory GM brake light switch, a 5 pin relay works great. Let me know if you need help wiring the relay. But if you have any electrical knowledge at all, you won't need my help.
so...under normal operation, when you use this lockup system, you will only lock up in 4th gear?
BTW, thanks for the information.
