700r4 problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2009, 05:34 PM
700r4 problem
hey guys i have a 1992 camaro 305 700r4 trans.automatic. Has been to the tranny shop several times already. Replaced converter ,pump and supossidly had the whole unit rebiult. Car idles good until i put it in gear. when in gear, it bounces up and down like i have a 572 big block in it. Ive been thru 2 converters a pump and the thing still doest run right. The fly wheel looks good and theres no play in the crank.I also replaced the tran mount. if any 1 has any idea as to what the prob could be,that would be great .gettin tired of spending my life at the trans shop.
Old 06-26-2009, 11:03 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Whoops...
Old 06-28-2009, 05:18 PM
700r4 problem
thanks for the reply puggsy. the car is a 92 camaro with an electric fan,not the old push style fan, found on old 350s. im takin it back to the shop 2morrow,to have a soliniod replaced cause the trans inst shifting into overdrive. i hope if i can get it on the lift and take a better look fron the underside i can better understand exactly where the source of the "bounce" is comin from. ill give a shout and let u know how it turns out.Thanks
89 Suburban 700R4 Problem JoeB Transmission - Rearend 13 11-06-2006 03:56 PM
700r4 TV Cable Problem jack71 Transmission - Rearend 7 10-25-2006 08:05 PM
700R4 Tranny Shift Problem riesman20 Transmission - Rearend 2 10-13-2006 10:21 PM
700r4 problem bmoon Transmission - Rearend 5 04-20-2004 12:01 PM
700r4 shifting problem 89chevstepside Transmission - Rearend 0 05-08-2002 02:10 PM
