700R4 problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2010, 03:53 PM
700R4 problem
my used 700R4 will not go into any gears . All gears want to pull forward even park wants to pull but all other gears including neutral pull like they are in drive?
Old 02-01-2010, 11:32 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Check 'S' link on the manual valve in valve body. Might have came loose.
Or, fried forward clutch. (rebuild time)
Old 02-02-2010, 01:03 AM
You are the 4th person to tell me the same thing but i have yet to be where it is or what it looks like. If you could help with that it would be appreciated.
Old 02-02-2010, 02:42 AM
SSedan64's Avatar
You'll have to drop the pan & check the linkage. Would be in top right area of this Pic, driver side front. Best Pics I could find.
http://www.rowand.net/Shop/Tech/imag...alWiring03.jpg
Rod that connects to Manual Valve in ValveBody.
http://www.rowand.net/Shop/Tech/imag...alWiring04.jpg
Old 02-02-2010, 05:36 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I must be an idiot, your post confuses me.
You post the trans will not go into any gears , yet you also post the trnas wants to pull forward in all shifter positions.
The link inside the trnas for the manual valve is not an S shape ,it is straight with bent hook shapes on each end.
If the link is correctly hooked up , then I suspect the forward clutch pack is damaged if the used trans wants to move forward in all shifter positions
Old 02-03-2010, 12:10 AM
C-10's Avatar
Revolution Calling
I was thinking TH350 on the 'S' link. It's the same basic part. Circled in photo. Straight line is the "link". I AM an idiot.
700r4 problem bullet xxx Transmission - Rearend 2 06-28-2009 05:18 PM
89 Suburban 700R4 Problem JoeB Transmission - Rearend 13 11-06-2006 03:56 PM
700r4 TV Cable Problem jack71 Transmission - Rearend 7 10-25-2006 08:05 PM
700r4 problem bmoon Transmission - Rearend 5 04-20-2004 12:01 PM
700r4 shifting problem 89chevstepside Transmission - Rearend 0 05-08-2002 02:10 PM
