700R4 Problem
I`m a New Member, Old Rodder, I have a Nice 1961 FORD STARLINER and have had a 700 R4 installed in lieu of the standard "Cruiseomatic". The Car has the "401" engine in it. 4:11 Gears .
The problem is that it seems to either go thru a half gear or is slipping from 2nd to 3rd. I can`t stand this. I want it to go 1,2,3,4. It acts like it`s going thru 5 gears. I`ve been told that it`s in the "Lockup". I don`t understand what this means, What is a "lockup?" What can I do to get this to shift right? Thanks Ed fsd2@cox.net |
Artificial Intelligence is no match for Natural Stupidity Chet |
The factory recommended adjustment of the 700R4 TV cable is as follows. Hold the throttle at wide open by what ever means available. Easiest to have somebody hold the go pedal to the floor. Depress the tab on the TV cable adjustment and tighten the cable until all the free travel is gone. I mean 'tight' . If it shifts too hard for your liking from 1st to 2nd, you can loosen the cable (very slightly), I mean, don't go more than 1/16" at a time. It is very sensitive. I attached the wiring diagram for manual control of the lockup converter. Don't forget to ground (pin D).
Good info there, Prof. I wired mine up with a LED lighted rocker switch.
Also, the 700R4 should shift three times and then the converter clutch should lock, which will feel like a 4th shift. Sometimes the 3rd shift and the converter clutch will lock nearly at the same time, so you might not feel the lockup. Try this thread first. Good luck and come back with more questions and don't forget to post when you get it going correctly. Oh, Welcome too! Last edited by Overdriv; 12-26-2011 at 04:13 PM. Reason: more text |
tv cable setting is definally important the lock up drops rpms about 300 rpms by locking the torque converter directly to the transmission elemating slippage it is done electricly unless a mechanical lock up conversion has been done .Under normal driving it should shift about 2500 rpm give or take afew rpms like mentioned in the aboved post you have to hsave the correct tv linage and adjustment
BTW, thanks for the information. |
If you want 4th gear lockup only, Go here.
This is the most desirable setup for completely automatic operation of the TCC. Or if you want more control of the TCC, which is more desirable to me check out the picture below. ETA: the references to switch locations and wire colors is for my application only. Yours will differ depending on how you do it. Good Luck! Happy New Year! Last edited by Overdriv; 01-01-2012 at 08:27 AM. Reason: clarifing |
Relay needed?
The first schematic shows no relay used, the second one shows a relay. Does the current draw demand a relay? Either way is fine for me...just don't want to overcomplicate it if it isn't needed.
One could do it without a relay but I've found a relay helps unload the switches and lets you use smaller wiring in your control section. Each to his own, I prefer to use relay for nearly everything these days. |
my vehicle is completely stripped of all the "factory" electrical stuff. everything is on switches now, the "brake" switch has a normaly closed switch but when you press down on the brake pedal it goes to an open switch, any reason why i shouldnt wire my tcc through that switch?
| 700r4 problem | yellowZ | Transmission - Rearend | 1 | 04-24-2011 08:11 AM |
| Another 700r4 problem | jasontay | Transmission - Rearend | 3 | 07-08-2008 02:08 PM |
| 700r4 problem. | ta boy | Transmission - Rearend | 2 | 06-03-2007 07:54 AM |
| 700r4, another problem | Dr. Cool, M.D. | Transmission - Rearend | 1 | 11-07-2005 07:03 PM |
| 700r4 problem | bmoon | Transmission - Rearend | 5 | 04-20-2004 12:01 PM |
