700R4 Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2012, 08:14 PM
blacklabzeke's Avatar
700R4 Problem
Have a problem with my 1988 700R4. It started with a WOT 2nd to 3rd upshift and then felt like the trans went into neutral. I have no fwd or reverse and there is no noise whatsoever. When I move the shifter it feels like there is a slight engagement in all gears, but vehicle will not move. I did a pressure test.
P 80 psi
R 125
N 80
D 80
3 80
2 125
1 125
Would appreciate any info before tearing this thing apart. Thanks in advance.
Old 10-19-2012, 10:41 PM
i had a 700r4 that did that clutches were gone had to rebuild it. didnt know what the pressures were
Old 10-20-2012, 06:38 AM
The trans was rebuilt about 20K ago. Here is a list of what was installed.
Rebuilt front pump with new vanes, rings and seals.
.500 TV boost valve
modified pressure valve
all new bushings, bearings and thrusts.
Beast sun shell
replaced rear planets, sun, reaction and ring gears
replaced front planets and ring
rear sprag and plate
all new seals
all new clutches (ALTO Gray) reverse, overunning, low reverse and forward.
New (ALTO Red Eagle High Performance) 3-4 clutch pack. .040 clearance.
Kolene steels modifed .125 apply plate 8 frictions 7 steels GM backing plate.
New (ALTO black) 2-4 band
New governor
New 1-2 and 3-4 accumulator pistons.
New valve body separator plate (TRANSGO)
Transgo 700jr kit w/ TV repair valve.
Old 10-20-2012, 08:18 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You describe a situation where the turbine hub inside the torque converter has broken out of the turbine.
The input shaft splines into the turbine hub, all power is transfered via this turbine hub. IF it breaks = no movement in any gears
Since you verified no movement in any gear selection, I suspect the converter
The Following User Says Thank You to Crosley For This Useful Post:
blacklabzeke (10-20-2012)
Old 10-20-2012, 08:28 AM
Once I pull the converter and transmission, how would I verify that this is the
problem?
Old 10-20-2012, 08:30 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
problem?
You have a converter shop check the converter.
Or use your snap ring tool to check the turbine hub
Old 10-20-2012, 08:47 AM
Thanks Crosley! Do you recommend opening the trans up to look for debris?
Old 10-20-2012, 09:53 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Turbine hub failure is typical damage is a clean break, not always as the parts are banging against each other.. I suggest dropping the pan for a debris check. If you replace the filter... break open the old filter, check for debris in the filter media.
Pulling the pump for a check is always a good idea since the trans is out any way
Old 10-22-2012, 08:03 AM
Do the pressure readings look OK? The readings above were at idle. When I pull the TV cable the pressure goes up, but the gauge bounces violently. Is this normal?
700r4 problem yellowZ Transmission - Rearend 1 04-24-2011 09:11 AM
700r4 problem bwblazer Transmission - Rearend 8 06-09-2009 10:35 PM
700r4 problem jasontay Transmission - Rearend 4 07-02-2008 07:31 PM
Another 700R4 problem dieselherb Transmission - Rearend 6 08-01-2006 08:04 PM
700r4 problem 85irocss Transmission - Rearend 4 10-28-2002 07:43 AM
