700r4 problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2007, 11:00 PM
700r4 problems
hello, this is my first thread so take it easy on me.I have a 85 k5 blazer 350 with 700r4. the tranny used to work perfect before i parked it now it seems like it wont engage unless i rev the rpms way up.I dont know much about trannies but the fluid level is the same as when parked.the tv cable hasnt been touched.Any ideas? thanks
Old 03-09-2007, 01:54 AM
brian0605's Avatar
mostly confused
Last journal entry:
how long has it been parked?? It really sounds like it is low on fluid. Don't mess with the T/V cable. If it was shifting fine when you parked it the cable is OK. The T/V cable changes how hard or soft it shifts, you get it wrong and you will burn up your trans. Brian
87 camaro 700r4 problems Dans83Olds Transmission - Rearend 3 03-13-2006 05:16 PM
700r4 tranny problems william27103 Transmission - Rearend 14 08-14-2005 11:37 AM
Will A 82 700r4 Fit Into My 85 C-10 Without Problems? hwdponce Transmission - Rearend 4 06-05-2005 06:35 PM
700r4 questions BIG DIXIE Transmission - Rearend 3 01-11-2005 07:55 PM
700r4 problems zmichalies Transmission - Rearend 14 08-19-2003 07:33 AM
