Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 problems
Thread: 700r4 problems
Old 06-27-2011, 07:37 PM
Overdriv's Avatar
Overdriv Overdriv is offline
The cable on a 700R4 is a throttle valve cable. It is imperative that it be adjusted correctly and have the correct geometry or the trans will not shift right and possibly not at all. If it came out of the truck you put it in then it's probably ok.
You need to take a pressure check of the trans and report back.
