700r4 problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2010, 12:38 AM
700r4 problems
I have a 91 chevy, 1500, 4x4. I just replaced transmission with a rebuilt 700r4, and I lost 2nd gear out of nowhere. All other gears work (reverse-overdrive) I was told that I should not have overdrive and that if I did that the transmission was junk. Is this true or can it be saved.
Old 01-08-2010, 08:41 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
At the 35 second mark on this video he shows the second apply piston. Could be that... http://www.youtube.com/watch?v=YfPgBUH6Ru0
Usually 2 and 4 leave at the same time (2-4 band). Sometimes reverse also ( reaction shell).
700r4 upshift problems LeAnnCallahan Transmission - Rearend 2 12-03-2009 01:33 AM
87 camaro 700r4 problems Dans83Olds Transmission - Rearend 3 03-13-2006 05:16 PM
700r4 tranny problems william27103 Transmission - Rearend 14 08-14-2005 11:37 AM
Will A 82 700r4 Fit Into My 85 C-10 Without Problems? hwdponce Transmission - Rearend 4 06-05-2005 06:35 PM
700r4 problems zmichalies Transmission - Rearend 14 08-19-2003 07:33 AM
