700r4 problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2011, 07:46 AM
700r4 problems
I have posted questions about this before so please be patient with me. I have a 700r4 from a 1985 Z28 in a 1985 S10 with a 350 engine the problem is when everything warms up to operating temperature the converter locks up and when I stop it is still locked up in first gear(this happens with or without the wires hooked to the trans) the solenoid is working and the valve is working. A shift kit was installed when the trans was rebuilt and it shifts very hard at normal starts. My question is is it possible the shift kit is making the line pressure to high or is it mechanical. I guess I'm kinda grasping at straws trying to keep from having to remove the trans again. Other than the first gear problem it works great and only has less than 500 miles on it. Thanks for taking time to look R W
Old 03-21-2011, 05:22 PM
I should have said I've posted questions about the 1st gear lockup and engine stall but I was wondering if the high line pressure from the shift kit could cause a bleed of fluid and cause the first gear lockup.
Old 03-21-2011, 09:20 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Nope, not if the trans is setup correctly.
the kits do not provide high line pressure at idle unless you are in to the full manual shift type valve bodys or the The constant pressure type valve body that TCI sells
700r4 problems yjsrule Transmission - Rearend 3 07-08-2008 05:00 PM
700r4 problems calhoun Transmission - Rearend 1 12-31-2007 10:24 PM
700R4 Problems only has rev.&1st chevy_2007 Transmission - Rearend 4 09-11-2007 01:35 PM
700r4 problems TJHarley Transmission - Rearend 7 03-14-2006 12:07 PM
700r4 problems shane horton Transmission - Rearend 2 10-27-2002 07:37 PM
