700r4 PROBLEMS - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2011, 11:05 PM
Phat Juan's Avatar
700r4 PROBLEMS
Latelly My 700 Is Really Weak After I Run Ot For Quite A Bit Or On A Hot Day The Gears Don't Shift As Good Especially O/d The Car Feels Week Pretty Much I Wonder What's Wrong....i Was Also Noticeing That My Buddy Has A 700 Aswell But He Has A Vaccum Line Going From His Carb To The Tranny While Mine Does Not Why Is This? And Last But Not Least I Plan On Rebuilding The Transmission A.s.a.p Before It Leaves Me Stranded Somewhere I Have A 350 With A Couple Mode Headers Intake 4 Barrel Cam.....etc N Was Wondering What Torque Converter Would Be Good For The 700 Trans I Use The Car On A Daily Basis For Now But I'm Trying To Have It Street Performance Nothing Drastic Like To Take It To The Strip Or Nothing Like That I Plan On Putting A Shift Kit On The Trans Bit I'm Not Sure What Would Be My Best Option With The Torque Converter N Would Like Some Opinions Or What Would Be My Best Option...thanks
Old 10-06-2011, 03:04 AM
SSedan64's Avatar
Soft shifts after the Trans get warm/hot is a sign of low pressure. Worn seals, too much clearance in the Pump etc..
A pressure test would help show what's going on in the Trans.
The best Stall for the TC would depend on the Cam and rear gear ratio.
700R4's don't use a Vacuum Modulator, so it doesn' need a Line from the Engine. It uses a TV/ThrottleValve cable which controls, line pressure, shift points, shift feel, part throttle downshifts and the detent downshifts.
Have you checked the TV cable adjustment?
http://www.jakesperformance.com/TV_C...etup_Info.html
http://purplesagetradingpost.com/sum...o/700R4p1.html
TV Info, 3-Parts >> http://www.tvmadeez.com/article/index.php
If you're using an Aftermarket Carb it will also need a TV geometry corrector bracket.
http://www.summitracing.com/parts/SUM-700203/
http://www.summitracing.com/parts/SUM-700202/
Old 10-09-2011, 09:58 PM
Phat Juan's Avatar
Well That I Know I Have A Cam That's A Step Below A 280...it Was A 270 Extreme Energy Comp Cam Or Something Like That I Don't Recall. N The Gear Ration On The Rear End Are 3.73.
Old 10-10-2011, 09:40 AM
SSedan64's Avatar
XE274H >> http://www.compcams.com/Company/CC/c...x?csid=87&sb=0 2200rpm stall recommended, so 2200-2500rpm stall would work well.
Old 10-10-2011, 10:20 AM
Phat Juan's Avatar
Manh Your Good......2200-2500 It Is...u Have Any Idea Of The Price Range I'm Looking @ By Any Chance?
Old 10-11-2011, 12:59 AM
SSedan64's Avatar
Price will depend on the Brand and if you use an (off the shelf) or custom TC.
For a mild Combo these should work fine. Good quality & very reasonably priced. Right row, 4th down.
http://www.roadrunnerconverters.com/gm.htm
4x4 700r4 Problems!! davidsawsu Transmission - Rearend 5 07-28-2011 09:02 PM
700r4 problems angel berdecia Transmission - Rearend 2 06-01-2011 06:44 PM
700r4 problems calhoun Transmission - Rearend 1 12-31-2007 10:24 PM
700r4 problems, wolfmeier Transmission - Rearend 1 05-17-2007 08:09 PM
700r4 problems zmichalies Transmission - Rearend 14 08-19-2003 07:33 AM
