700r4 problems
I have a 1990 chevy 1500, i bought a used 700r4 to put in it, i hooked up the linkage right all the wires are plugged in and it has fluid. when i put it in drive i got nothing and the same thing into reverse it feels like there is nothing in the tranny need help thanks!
did you put fluid in the torque converter?or the manual valve is not hooked up
dont ever buy a used 700 there usually shot or very close to |
You need to pressure test it,that will tell you what's going on.Theirs a port just above the gear shifting linkage,it has a pipe threaded plug,its 1/8 npt.Go to the hardware store get a male 1/8 threaded nipple w/barbs on it,then about 3 ft. of hose that can handle 300 psi. then a pressure gauge that will read to 300 psi. Then another nipple female w/barbs that will thread on to the gauge.Get the engine up to temp.then read your pressures in P R N D 3 2 1,write those pressures down. Then post them on here an someone can give you a better answer.Without those its anybody's guess to what the problem is. A good 700r4 will have around 180 psi. at idle in all gears.Also be sure to clamp to hoses down to the nipples.For hose I used some a/c hose like the kind you find to recharge an a/c with an also used an a/c gauge.
| 700r4 problems | machminer | Transmission - Rearend | 11 | 09-30-2008 06:52 AM |
| 700r4 problems | shaun3636 | Transmission - Rearend | 3 | 08-26-2008 10:47 AM |
| 700r4 problems | yjsrule | Transmission - Rearend | 3 | 07-08-2008 05:00 PM |
| 700r4 problems | tcreger | Transmission - Rearend | 1 | 03-09-2007 01:54 AM |
| 700r4 problems | cybermca | Transmission - Rearend | 2 | 03-23-2003 05:13 PM |
