700r4 problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2006, 03:01 PM
700r4 problems
An 85 chev stepside 4x4 followed me home in 85..It"s a 305ci with 308 gears.She"s definately not a 1/4 miler....
The trans started making a slight grinding noise when put into 1st or reverse.It starts out in first fine, but I have to drive around the block once to get it to shift. Once it shifts ur good to go. It"ll shift up and down all day with no probs. Fire it up in the morning and same thing over again.
Could it just be the torque converter as thats where the sound seems to be coming from?
Never driven hard but she"s got 150000 miles.
Any suggestions from you trans experts? Thx Ted
Old 03-13-2006, 07:10 PM
Wow. 150K on an original '85 700R4 is amazing in itself...
However, noise in 1st and reverse is usually the low/reverse planet.
The no-upshift cold/first of the day seems to be stuck TV valve or governor. They don't "fix" themselves by driving. I just know that a rebuilt trans will fix both problems. Make sure the check for planetary damage. If so, replace the trans cooler(s)
Old 03-13-2006, 08:40 PM
Thx for the reply.....I just knew you were going to say that......so what ur telling me is 'there is no easy fix' damn.......
Ted
Old 03-13-2006, 08:58 PM
Jmark's Avatar
Is the noise there when sitting still but in gear? Or only when you begin to get it moving? If its noisey sitting still, the rear planet won't be moving yet and the noise could be from some other place.
Mark
(NOT an expert by any stretch of the imagination! LOL)
Old 03-13-2006, 10:29 PM
Mark
yes its just a slight grinding noise in gear brake on........takes off in gear fine.....no slipping.....just wont change until I go around the block once or twice......go fish!!! Thx for the reply Ted.....
Old 03-14-2006, 11:00 AM
Ozz1967's Avatar
Air Force Guy
Thx Ted
I would say that's your problem right there. hehe I just rebuilt my 700R4 and it had just over 100k miles on it. If it's grinding, you've got something inside that's not moving properly and the only proper way to find out is to pull it apart and have an "expert" look at it. Sorry I can't be of more help but those mid 80's GM vehicles have never done well once they hit 100k miles. Kind of like living on borrowed time after that! hehe Good luck Ted!
Old 03-14-2006, 11:56 AM
That"s not the answer I was looking for...lol
I was hoping someone would come on here and say "It"s probably your torque converter"
Thx for the reply
I"ll take Grinding noises in the 700r4 transmission for 200 dollars Alec.........
Old 03-14-2006, 12:07 PM
Ozz1967's Avatar
Air Force Guy
hehe I was referring to the 150,000 miles as your problem. The thing is just plain old and probably more than a little tired. I'm sorry I can't help more than that. hehe
700r4 governer gear problems chevcamz28newbie Transmission - Rearend 3 03-13-2006 07:26 PM
87 camaro 700r4 problems Dans83Olds Transmission - Rearend 3 03-13-2006 05:16 PM
700r4 shifting problems with transgo kit mb9900 Transmission - Rearend 18 08-14-2005 08:20 PM
Will A 82 700r4 Fit Into My 85 C-10 Without Problems? hwdponce Transmission - Rearend 4 06-05-2005 06:35 PM
700r4 problems zmichalies Transmission - Rearend 14 08-19-2003 07:33 AM
