Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 problems after rebuild
Old 04-11-2013, 08:35 PM
91chevyss's Avatar
91chevyss 91chevyss is offline
I didnt air check it and I should have but I thought it was the shims that i installed from the transgo kit so I pulled the cover and pulled everthing out and reinstalled the factory spring and snap ring in the servo. Then pan gasket is a cork gasket. Is it possible to air check the servo with the trans in the truck. will it downshift from 3-1? I dont really want to dog it or burn the trans up. I thinking the same thing that I only have 1st and 3rd but would I be able to manually put it in second if the servo was leaking?
