Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 problems after rebuild
Old 04-14-2013, 08:27 AM
jed971959 jed971959 is offline
if I remember right you can check the band by having someone inside to run it up though the gears on jack stands and you push in on the servo cover to apply the band . to check if you missed the band drop the pan and look by the shifter linkage by the valve body you can see the band there . if you push and hold on the servo cover you should see the band move to hold the drum. with a screw driver check that it is holding the drum from moving.
