Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 problems after rebuild
Old 04-14-2013, 11:10 AM
91chevyss's Avatar
91chevyss 91chevyss is offline
i took it for a drive yesterday and it will manually go to second and it will shift out of 1st at 3000 when in od but dont feel anything after that but mph increases fairly well and its not down shifting that i know of but i did floor it on the way back and i guess it came out of adjustment because it wont stay in gear unless i have the gas half way down. could it be the clearance in the 3-4? i put the same amount of steels and clutches but took out the helper springs which transgo said to do. could it be the 4 seals that are on the input shaft that the pump sit on? anything else before i pull the trans back out? also unhooked top line at radiator and fluid shot out.
