-   -   700r4 problems after rebuild (http://www.hotrodders.com/forum/700r4-problems-after-rebuild-231718.html)
91chevyss 04-10-2013 09:16 PM
Ok Im wondering if you can help me. I got the trans installed back in the truck and Im having some problems. I have reverse neutral 1st and I believe 2nd not sure about 3rd or 4th. When I take off I feel it shift out of 1st and Im not sure what gear its goes too but its not that hard or firm like i thought it would be and I dont really feel it shift any more but i can get up to atleast 60 or more but its not really over revving like if it was 2nd and I dont think I could reach that mph in 2nd gear. I also dont really feel a downshift. I had a friend that does some work on transmissions and he adjusted my tv cable to where it should atleast shift through all gears. I rebuilt it with a transgo 700 2-3 reprogramming kit and a corvette servo and .500 boost valve the rebuild kit came from monster trans but just a delux kit I belive. Thanks please help.
dogwater 04-11-2013 07:14 AM
Botieoverdrive has a real good TV cable adjustment guide. Take a look at it then readjust.
jed971959 04-11-2013 08:12 AM
did you air check your sero after installing it
sounds like its going 1-3
maybe a cut seal on servo
jim
91chevyss 04-11-2013 07:35 PM
I didnt air check it and I should have but I thought it was the shims that i installed from the transgo kit so I pulled the cover and pulled everthing out and reinstalled the factory spring and snap ring in the servo. Then pan gasket is a cork gasket. Is it possible to air check the servo with the trans in the truck. will it downshift from 3-1? I dont really want to dog it or burn the trans up. I thinking the same thing that I only have 1st and 3rd but would I be able to manually put it in second if the servo was leaking?
jed971959 04-14-2013 08:04 AM
not with out droping the valve body
you may have missed the band when putting the servo back in
jim
jed971959 04-14-2013 08:27 AM
if I remember right you can check the band by having someone inside to run it up though the gears on jack stands and you push in on the servo cover to apply the band . to check if you missed the band drop the pan and look by the shifter linkage by the valve body you can see the band there . if you push and hold on the servo cover you should see the band move to hold the drum. with a screw driver check that it is holding the drum from moving.
jim
91chevyss 04-14-2013 10:10 AM
i took it for a drive yesterday and it will manually go to second and it will shift out of 1st at 3000 when in od but dont feel anything after that but mph increases fairly well and its not down shifting that i know of but i did floor it on the way back and i guess it came out of adjustment because it wont stay in gear unless i have the gas half way down. could it be the clearance in the 3-4? i put the same amount of steels and clutches but took out the helper springs which transgo said to do. could it be the 4 seals that are on the input shaft that the pump sit on? anything else before i pull the trans back out? also unhooked top line at radiator and fluid shot out.
jed971959 04-14-2013 12:00 PM
only things I would do is check the valve in the govener and play with the t.v cable adjustment .
jim
91chevyss 04-14-2013 01:35 PM
im gonna order a new tv cable tonight or go to dealership tomorrow on lunch. I looked at the governor before i put it in the trans but I can take a look at it tomorrow because its still wet outside. Do i need the tv corrector bracket? summit has one for $20. any valves in valve body that would cause this?
jed971959 04-15-2013 07:25 PM
was this tranny in and worked before the rebuild or is it a swap. for the time it takes to drop the valve body and check I would check it first
if nothing else works before pulling the tranny . did the rebuild kit come with 2 sets of valve body gaskets (aux and non aux valve body gaskets)
91chevyss 04-15-2013 08:23 PM
The trans is the original one that came with the truck. when I still had tbi it was working but not completely it started loosing third and just before it was suppose to go to third it would rev up and i would let off the gas and then it would go in gear and I could keep going and would also downshift when ever I wanted it to. well I wanted to switch to carb which was an edelbrock and when I done it my factory bracket was to far back at the original spot for the cables to reach the carb so I moved the bracket up a bolt hole and im currently using only one bolt to hold down. After the carb swap it would still down shift and go through all the gears but under full throttle after it was in 4th I belive it started slipping because my rpms would go back and forth a little. once i got the money I ordered the transgo 700 2-3 and a rebuilt kit with new clutches and steels, band, seals, a corvette servo and a .500 boost valve and so on but just before i pulled the trans i messed with my adjustment on the tv cable to see if that what was causing the full throttle slip but I never got to test drive before I pulled it. The rebuild kit came with two sets of valve body gasket and I have aux. vavle body also the transgo kit came with a set of valve body gaskets so I have an extra set. I didnt order the tv cable yet but I ordered the tv cable geometry corrector bracket that goes on the side of the carb from summit last night. [IMG]http://i1321.photobucket.com/albums/...ps00b5ac96.jpg[/IMG]
91chevyss 04-15-2013 09:10 PM
was i suppose to leave out any check balls with the transgo kit or do they all go back in. Also it required to plug holes which i did.
jed971959 04-15-2013 10:25 PM
don't know about the shift kit or what it tells you to do or leave out
double check which valve body gaskets you used
91chevyss 04-15-2013 10:39 PM
Im gonna try to call transgo tomorrow and see what they say but I can take some pics of the instructions but there a little dirty lol. the instructions only showed some of the checkballs but didnt say anything about leaving any out and Ill check the gasket I have tomorrow. Thanks for the help
91chevyss 04-16-2013 06:46 PM
installed tv corrector didnt really help but i floored it and it wouldnt down shift also floored it starting in 1st and manually went to second and nothing shifted to drive and it shifted then i went to od and no change. 3000 at about 60 or 65 with 3.73 s and it should be around 2000-2400 i believe.
