700R4 Pukes Fluid - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2006, 03:48 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
700R4 Pukes Fluid
A friend has a 84 Corvette, He bought the car non-running. Over the winter he had a 383 sbc built and he installed it in the car with the 700 that came in the car. He has had this running and it is drivable. The problem is that when it sits for a couple of weeks after driving, it takes a tranny fluid dump on his garage floor. He believes it is coming out of the vent tube on the trans. If he drives it weekly it wont dump. Trans fluid has to be added to top off each time this happens.
Anyone have any ideas as to what may be happening?
Thanks
Old 05-02-2006, 06:58 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks
torque converter drains back into the tranny as the car sits . The tranny will leak at spots when the fluid level is raised higher than normal as the car sits for a long time.
this is common to all automatics with a torque converter
Old 05-03-2006, 05:12 AM
1ownerT's Avatar
Wiki Edits: 4
Thanks, Crosley
Is this something a rebuild will cure? Would he be better off locating a different trans and or converter? I've never seen this before. I have had cars sit, sometimes for months at a time without doing this.
Thanks again
Old 05-03-2006, 06:17 AM
snod83's Avatar
I would suggest just starting the car and letting it run weekly. I have a 700r4 in my Nova and it pukes its guts over the winter, as does the th350 in my T-bucket. Its not a real big deal if they are run weekly though. Also, don't drive it until you refill it.
Ryan
Old 05-03-2006, 06:25 AM
malc's Avatar
Living At The Speed Of Life
Check the rubber grommets for the tranny dipstick tube or detent cable.
Old 05-03-2006, 06:31 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
check all areas on the trans for leaks.
shifter linkage,
filler tube
TV cable area
pan area
clean up trans case and watch for leaks.
sometimes the fluid will travel on the edge of the pan rail.. then drop of many inches from the actual leak.
Old 05-04-2006, 11:02 AM
1ownerT's Avatar
Wiki Edits: 4
Thanks to everyone who replyed, I will pass on the information.
Jeff
700r4 is fluid routed to cooler when TCC is off eliotmansfield Transmission - Rearend 3 02-12-2006 06:56 PM
4x4 700R4 to 350 swap Davesblazer87 Transmission - Rearend 4 12-22-2003 07:59 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
how low on fluid (TH350) before it quits moving? HotRodF100 Transmission - Rearend 4 10-11-2002 06:34 PM
Dot 5 Silicone Brake Fluid?? Yes or No ?? Jim Weeks Suspension - Brakes - Steering 18 04-15-2002 06:22 AM
