Hotrodders Bulletin Board
#1
700r4 question
While driving today, I had a down shift problem in my 67 camaro which has a 700r4. As I gave it throttle to downshift "passing gear", it wouldn't shift down. The engine also started sputtering as I gave it full throttle and it wouldnt down shift.
#2
re: 700r4 question
Are you sure it's a trans problem?? A trans will not shift properly if the engine is not performing correctly. With the engine sputter you need to check the fuel filter or possibly fuel pump starving the engine for fuel. It may run good at slow to moderate speeds and fall on it's face when you need to get into passing gear. The reason I say this I have repaired a car for a friend who had a similar complaint,and have seen it several times since.I reread what you said about the T/V cable and it doesn't make it kick down it controls how soft or firm your shifts are. The governor controls the kick down. At least that's the way I remember it.
Last edited by brian0605 : 02-20-2007 at 07:19 AM. Reason: forgot to mention the t/v cable |
#3
700r4 reply
I appreciate the info. Im going to take the car to a friends house and have him check it. I called him today and said to bring it over this weekend. Im hoping its a minor problem. Im hoping the kick down cable just needs adjusted. Ill let you know what happens.
#4
re: 700r4 question
#5
re: 700r4 question
thanks, 38chevy3wcoupe, That's a really good article!! Lots of good info. I used to think the same thing,and on different transmissions years ago that is what that cable was!!! not so anymore.That's what I was tring to explain to danscam, I have seen transmissions do weird stuff when the engine wasn't performing properly.
Back to top |
Similar Threads for: "700r4 question"
| another 700R4 tranny question ?? | cares | Transmission - Rearend | 6 | 06-16-2006 01:26 PM |
| 700R4 Question | Not A T 25 | Transmission - Rearend | 5 | 06-12-2006 11:16 AM |
| New Guy and a 700r4 question | John Fabris | Introduce Yourself | 5 | 05-10-2006 09:20 AM |
| 1984 700R4 B&M Shift kit question | Russell52 | Transmission - Rearend | 4 | 02-25-2004 09:45 PM |
| 87 Camaro 700R4 Question | Dans83Olds | Engine | 6 | 05-07-2003 09:39 AM |
