700r4 question
Hey guys I've got an 1988 700r4 and I can't get the apply piston out of the bottom of the case. My spring compressor keeps popping out of the luggs in the case. I can push the spring retainer down just a little bit but compressor pops loose if I go any further. This is my first tranny rebuild and from what I've heard I picked a good one. Any suggestions or tips will be GREATLY appreciated
Now that I know that the reatainer goes down very little, I know that I'm going in the right direction. It just does lossen the tension. Also, I'm having a tough time getting the snap ring out. I can't find the pair with the bent tips anywhere. Is there anything else that I can use?
often the revers piston spring retainer inner hole is too tight to slide over the case . this can make it difficult to remove and install this retainer..
i slightly grind the ID of the retainer to gain clearance
At the Bonneville Salt Flats, first gear is known as 130 mph. |
| another 700R4 tranny question ?? | cares | Transmission - Rearend | 6 | 06-16-2006 01:26 PM |
| 700R4 Question | Not A T 25 | Transmission - Rearend | 5 | 06-12-2006 11:16 AM |
| New Guy and a 700r4 question | John Fabris | Introduce Yourself | 5 | 05-10-2006 09:20 AM |
| 1984 700R4 B&M Shift kit question | Russell52 | Transmission - Rearend | 4 | 02-25-2004 09:45 PM |
| 87 Camaro 700R4 Question | Dans83Olds | Engine | 6 | 05-07-2003 09:39 AM |
