700R4 Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2012, 07:16 AM
DoubleVision's Avatar
700R4 Question
I've got two vehicles that have the same issue. Both are 4x4's.
One is a '89 model the other a 88 model. Both trans have been overhauled in the past however I am unsure of when. The issue is when you start it, put it in gear and place it in the OD position, normally it would start out in 1st and so on. What both of these are doing is acting like they are going into OD, as you can give it a little pedal and it won't move. You can feel it trying to somewhat. However If I pull the shifter into 3rd, or the standard drive position and it goes into 1st gear like it's supposed to. Then I just move it up to the OD position and it stays in 1st gear and shifts out just like normal. OD seems fine going down the road as well. When I pull up to a stop sign, it goes back down to 1st gear as usual and shifts out fine again. But if I park it, shut it down, then get back in it and go 5 minutes later, again I have to repeat the process of pulling it back down to 3rd again to make it operate correctly. Any help on the subject is much appreciated.
Old 05-03-2012, 08:52 PM
the 700R4 is tricky if fluid isnt correct by either being too low on fluid or the TV cable on the carb make sure there isnt any slack in it at WOT.
700R4 Corvette Servo question, (pin question) Guntar13 Transmission - Rearend 3 11-10-2011 12:05 AM
700r4 question 03eiger Transmission - Rearend 3 07-28-2007 08:46 AM
700r4 question Danscam Transmission - Rearend 4 02-21-2007 08:42 AM
700R4 Question Not A T 25 Transmission - Rearend 5 06-12-2006 11:16 AM
700R4 Question Pdick72 Transmission - Rearend 1 01-13-2006 03:43 PM
