700R4 question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2012, 02:51 PM
wmwise's Avatar
De Oppresso Liber
700R4 question
Howdy, I picked up a 700R4 to install in my International pickup to chevy drivetrain conversion.
I want to rebuild it before I install, but not sure on what year the tranny is, and I noticed they make about 3 kits depending on tranny year.
How can I tell which year I have so I can get the right rebuild kit ??
Thanks for the help
Bill
Old 07-01-2012, 03:43 PM
wmwise's Avatar
De Oppresso Liber
I looked at the pad on the pass side where the numbers are suppose to be, but nothing there. The trans was suppose to have come out of a 87 suburban but not positive on that. Plus they make 2 different kits for 1987..an early and a late.
Hoping someone can help
Thanks
Bill
Old 07-03-2012, 07:04 AM
Last journal entry: Still running strong
I think one has the aux. valve body (their will be a tube running from the front of the valve body to the rear of the v.b.) This is the newer one.The older style of v.b. wont have the tube.You will have to take the pan off to see it.
The Following User Says Thank You to dogwater For This Useful Post:
wmwise (07-03-2012)
Old 07-03-2012, 07:13 AM
If it does not have the aux.valve body then I wouldnt mess with it.Those were weak .Not worth the trouble of rebuilding.
wmwise (07-03-2012)
Old 07-03-2012, 08:31 AM
wmwise's Avatar
De Oppresso Liber
Thanks for the info.... I will pull the pan and see what I have.
Old 07-03-2012, 11:13 AM
wmwise's Avatar
De Oppresso Liber
I pulled the pan and it does not have the aux valve body, plus there was a ton of crap in the bottom of the pan. So to the junk yard it goes
I have a good turbo 350 so looks like I will be using it. Really wanted to overdrive and lower gears, but budget is tight, so will have to use what I have. Can always upgrade later.
Thanks for the help guys !!
700R4 Corvette Servo question, (pin question) Guntar13 Transmission - Rearend 3 11-10-2011 12:05 AM
700R4 question DrBee8457 Transmission - Rearend 3 12-22-2007 11:15 PM
700r4 question 03eiger Transmission - Rearend 3 07-28-2007 08:46 AM
700r4 question Anton Transmission - Rearend 2 07-08-2005 05:02 PM
another 700r4 question firebomb71 Transmission - Rearend 2 10-08-2003 08:10 AM
