700r4 question - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 08-15-2004, 02:38 AM
bowtiedude69's Avatar
Another crazy plowboy!
700r4 question
I have a 700r4 in 88 4x4 mildly mod 355. Installed goodwrench 700r4 worked fine however I couldn't leave well enough alone installed b&m shift kit now 1-2 shift firm 2-3 rpm flares about 200rpm but does shift 3-4 firm in od pos . Now if you shift manually all shifts are firm should I install a heavy-duty servo like vette , tci etc or is that indicative of impending doom?? .
Old 08-18-2004, 11:18 AM
chev38's Avatar
Last journal entry: On the way to get worked on in KC
Sounds like a pressure problem. Try adjusting the TV cable per BoTiOverdrive(sp) specs.
http://www.tvmadeez.com/
This is the critical adjustment on 700R4 trans.
