Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 06-24-2005, 07:44 PM
Anton Anton is offline
700r4 question
Hi. I have a stock 700R4 other than a TCI rebuild kit and B&M heavy duty rv shift kit.
IT shifts too soon for it's cuttrent application (lifted 4x4 with big tires and a low power 305. The gearing is good but the 305 is just tired.
My question is, will it hurt the 700r4 to manually upshift it through the gears WHILE accelerating? Or should i let off the gas before upshifting?
Thanks
Old 07-08-2005, 04:49 PM
BigDawgsEatFirst's Avatar
BigDawgsEatFirst BigDawgsEatFirst is offline
400SBC4Life
re: 700r4 question
Dude
this is a trans guru question
Old 07-08-2005, 05:02 PM
NXS's Avatar
NXS NXS is offline
re: 700r4 question
Manually shifting second gear will add extra abuse from what I understand.
Can you adjust the TV cable tighter?
or put new weights in the governor?
and there is also a stiffer TV spring for the kickdown in the valvebody.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "700r4 question"
700R4 Mounting Question mike bryan Transmission - Rearend 6 11-05-2004 05:14 PM
700r4 torque converter to flex plate question BR57 Transmission - Rearend 6 10-05-2004 12:41 AM
700r4 question bowtiedude69 Introduce Yourself 1 08-18-2004 11:18 AM
700r4 servo question chevcamz28newbie Transmission - Rearend 4 08-08-2003 12:53 AM
700r4 band question chevcamz28newbie Transmission - Rearend 0 08-05-2003 12:46 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
