700R4 Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2006, 02:50 PM
700R4 Question
I have a 700 trans. I bought it rebuilt. I was told it has a shift kit in it and a .50 valve(??). When it shift from 1st to 2nd it will snap your neck back( is this normal with a shift kit?). It shifts though all 4 gears. I've heard that with the electric hook that it should shift one more time(a slight RPM drop). Is this true?
I do not have the wires hooked up yet. will this hurt the trans?
Thanks
Old 01-13-2006, 03:43 PM
The electric part is the lockup solenoid. After it is wired up it will lock the converter when you energize it.
1984 700R4 B&M Shift kit question Russell52 Transmission - Rearend 4 02-25-2004 09:45 PM
Hotrodders Guidelines -- READ ME Jon Hotrodders' Lounge 0 06-14-2003 05:08 PM
Hotrodders Guidelines -- READ ME Jon Hotrodders Site Suggestions and Help 0 06-14-2003 05:07 PM
87 Camaro 700R4 Question Dans83Olds Engine 6 05-07-2003 09:39 AM
