700R4 Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2006, 11:01 AM
Not A T 25's Avatar
Takes Guts To Cut One Up
700R4 Question
I have installed a Mad Dog 700R4 with hyd lock up and there is a fitting on top of the trans housing that looks like a vacuum line fitting but I found out the hard way that it is not "thats another story" my question is should this line be left open for a vent or capped?
Success is getting what you want but happyness is liking what you get.
Old 06-03-2006, 11:52 AM
Jmark's Avatar
If its a small plastic tube about 3" long and 1/8" diameter, its a vent and needs to stay open. It just hangs there, no biggie!
Mark
Old 06-04-2006, 04:54 AM
BigDawgsEatFirst's Avatar
400SBC4Life
what do u mean thats another story.
proper install of your 700R4 is a must
I know you did not ask but
The cable thats on your tranny is a throttle valve cable.(T.V.)
T.V. Cable adustment is just as important as the right amout of fluid
your Warranty depends on it.
Ask all the questions before starting or driving
Old 06-04-2006, 08:19 AM
Not A T 25's Avatar
Wow! didn't ask for that one! not sure why you got on your high horse but I also installed an new 383 and had low vacuum and that was because I had hooked up the trans over flow thinking it was a vacuum like my TH350. Take a chill pill not the first car I have built just the first 700R4. Thanks for the help though
Old 06-08-2006, 11:07 AM
400SBC4Life
I am not trying to be a .....
But no one tells you till its too late.
If the cable adjustment is not correct
It will cause not enough pressure on your clutches when you get on it and wont downshift from 2nd back to first properly and you know the rest.
I just want you to have success with the 700
Old 06-12-2006, 11:16 AM
Not A T 25's Avatar
No problem I appreciate your thoughts I sure don't want to trash a new Trans!
New Guy and a 700r4 question John Fabris Introduce Yourself 5 05-10-2006 09:20 AM
1984 700R4 B&M Shift kit question Russell52 Transmission - Rearend 4 02-25-2004 09:45 PM
Hotrodders Guidelines -- READ ME Jon Hotrodders' Lounge 0 06-14-2003 05:08 PM
87 Camaro 700R4 Question Dans83Olds Engine 6 05-07-2003 09:39 AM
