700r4 question (General Knowledge...I think) - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2012, 07:28 PM
Last journal entry: 76
I have a 700r4 and it goes into first and most of the time 2nd but it will sometimes go into 3rd and sometimes it wont. what is my problem?
is that valve body problems or maybe transmission filter stuff please help thanks!
Old 04-16-2012, 09:01 AM
SSedan64's Avatar
Has any work been done to it?
Mileage on Trans?
When it does go into 3rd, is it a firm or slipping shift?
What about 4th gear?
Old 04-16-2012, 10:45 AM
I dont know much I would have to ask my buddy today he gave it to me.
the way he talked he said once it went into gear it would do fine it just didnt like to shift as for mileage I am unsure I will ask him about it today.
I think it has 1xx,xxx miles on it but I will get a better estimate today and post back.
Old 04-16-2012, 06:21 PM
my buddy didnt know much about mileage but he said it would go into second most of the time pretty easy but rarely went into 3rd or 4th(OD) but when it does go it doesnt shift hard. any suggestions?
Old 04-17-2012, 07:11 AM
rick 427's Avatar
Last journal entry: 33 WILLYS
Did you really put this trans in a car knowing it wasn't working right before you put it in??
Old 04-17-2012, 10:18 AM
no I want to fix it before I put it in.
Old 04-17-2012, 10:19 AM
that is if I can fix it
Old 04-17-2012, 11:35 AM
SSedan64's Avatar
With that mileage & those symptoms it will probably need a complete overhaul. 3-4 Clutch pack is probably smoked etc...
Do you know what Year model it is?
87-92/93 models are the best Cores to build, the newer the better. They have the most Factory upgrades. Older models cost much more to build if you upgrade internal Hard parts.
Old 04-17-2012, 03:29 PM
I have never rebuilt a tranny before rebuilt 2 or 3 engines just no trannys :/ but the transmission came from a 83 shortwide chevy that had a 383 in it.
Old 04-17-2012, 03:30 PM
although im pretty sure its not factory I will have to check numbers if it has any.
it is electronic though.
Old 04-19-2012, 12:17 AM
SSedan64's Avatar
93/93 & newer 700R4/4L60 are Electronically controlled.
82 thru 92/93 only use Electric for TCC lockup control.
TCC = TorqueConverterClutch.
Look in the Knowledge Base for 700R4 ID Info.
Old 04-19-2012, 06:11 AM
ok this one only has two plugs for electrical the kickdown is cable the speedometer is electric and the other plug im not sure of.
Old 04-19-2012, 06:12 AM
this is going to cost more to rebuild than a tail housing for my th400 so I will just fix the th400.
Old 04-19-2012, 06:59 AM
SSedan64's Avatar
TCC should have a 4-Pin plug like this > http://www.hughesperformance.com/pdfs/HP700-R4.pdf
The TV/ThrottleValve cable adjustment is the most important piece of the 700R4. It controls line pressure, shift points, shift feel, part throttle downshifts and the detent downshifts.
Too loose = low pressure, early, soft shifts & burnt clutches.
TV 101, 3-Part Article >> http://www.tvmadeez.com/article/index.php
You'll miss the 700-R4s' low 3.06 1st gear and .70 4th/Od gear if you swap to the TH400 Trans.
GM Trans Gear Ratios:
Trans--------1st-----2nd-----3rd------4th Gear----
TH400-------2.48----1.48----1.00-------------------
TH700R4-----3.06----1.62----1.00------0.70----------
Old 04-19-2012, 03:04 PM
mine has the TCC connector I dont think it would be worth the trouble to fix it though.
sbc timing question and carb question.....i am ready to absorb your knowledge c_cham Engine 16 02-12-2011 11:26 AM
Brake booster question; need some knowledge HammerGVette Suspension - Brakes - Steering 1 02-25-2010 12:58 AM
700R4 General Questions. LOWbutnotSLOW Transmission - Rearend 10 07-09-2009 11:20 PM
Hotrodders Knowledge Base: General Rodding Tech Jon General Rodding Tech 0 11-26-2005 06:43 PM
