700R4 Rattling Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2010, 07:13 PM
Did a complete overhaul on a 700R4 in a 1992 full size Chev van. Everything was checked very closely and all of the components were within factory specs. Installed a rebuilt torque converter. The transmission worked perfect for about two weeks and then the other morning I started the van and it sounded like something was rattling in the front of the transmission. Almost sounds like something is rolling around in the flywheel cover. It has to be something in the transmission because my 1-2 and 3-4 shift points are way too high. Any ideas?
700r4 problem bullet xxx Transmission - Rearend 2 06-28-2009 05:18 PM
89 Suburban 700R4 Problem JoeB Transmission - Rearend 13 11-06-2006 03:56 PM
700r4 TV Cable Problem jack71 Transmission - Rearend 7 10-25-2006 08:05 PM
700r4 problem bmoon Transmission - Rearend 5 04-20-2004 12:01 PM
700r4 shifting problem 89chevstepside Transmission - Rearend 0 05-08-2002 02:10 PM
