700R4 rear seal leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2006, 06:51 PM
I put a 700R4 in my 55 last year(had 350 turbo). I have a problem now with the rear seal leaking. I replaced it with a new one but it still leaks. It leaks quite a bit when sitting still with out the engine running. I get a good size puddle after a few days. Does any one have any ideas as to what could be causing this leaks. Could the yoke have anything to do with this?
Old 04-03-2006, 07:03 PM
You could have a yoke problem. Check the polished area of the yoke. It must be smooth and even, no wear in the bushing area. If the yoke is worn, replace it and the tailshaft bushing. Also check to see if the yoke has a rust area (even if it was polished) where the seal surface is riding. This will cause the seal to leak past the rust. Check to see if the yoke has a breather hole drilled in the center of the welch plug in front of the U-joint. If so, it needs to be welded shut, or get a yoke seal sleeve from a trans shop. These were commonly used in 2wd trucks and vans.
Old 04-03-2006, 07:13 PM
That sounds very possible. It didn't take long to start leaking again after I put the new seal in. Almost immediately. I knew a heck of a lot more about these old cars when I was a teenager. I just started back on them three years ago and I realize that I forgot a lot in 40 years. Thanks for your advise!
Oil lost through rear seal? TVR383 Engine 1 11-09-2005 01:09 PM
400 sbc rear main seal el Engine 2 07-18-2004 09:37 PM
Rear of engine oil leak 350 western star Engine 5 07-13-2004 03:32 AM
rear main leak vetteman Engine 2 07-04-2004 09:29 PM
Replacing rear seals on a 700r4 Jag Daddy Transmission - Rearend 1 05-27-2003 02:45 AM
