Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 rebuild 3-4 lower pressure plate
Old 03-21-2013, 08:04 PM
91chevyss's Avatar
91chevyss 91chevyss is offline
an update when I pulled everything out to replace check ball in the input drum and as I was reassembling everything I took a look at the old steel that was above the lower pressure plate and it had the same wear marks as the stepped sided of the plate so does the stepped side need to face or does it matter. I figured the stepped side needs to face me since the marks matched up to an old steel.
