Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 rebuild 3-4 lower pressure plate
Old 03-21-2013, 08:42 PM
rick 427's Avatar
rick 427 rick 427 is offline
Last journal entry: 33 WILLYS
The side of that plate where the lugs are flat/smooth along with the rest of the surface:i.e. completely machined evenly thru the entire surface,faces you when installing....the other side,which is a thin machined ring,and the lugs are not machined,faces down. Thats the piece you are referring to,correct?
