700r4 rebuild... to go heavy duty or not?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2010, 01:41 PM
Wac Wac is offline
My 700r4 is behind a SBC in a jeep wrangler. It needed to be rebuilt after I took it swimming... (don't ask...). I tow a 4000lb boat/trailer with it and the rig itself weights about 4000lbs with ford rear end, 33" tires, full size spare, back seat for kids, and the list goes on.
The shop i took it to suggested a "heavy duty" rebuild which involves a bunch of new/upgraded parts: heavy duty 3-4 clutch packs, 5 pin front planetary, front plnetary hub, 5 pinion rear planetary and some changes to the pressure the pump puts out to keep line pressure a little higher.
They also suggested upgrading to a corvette servo to firm up the 1-2 shift... about $50.
To all those trans guys out there... 2 questions (be honest please!!)
1. is this worth the extra $550 the shop wants for the "HD Rebuild parts" or should I stick with the standard rebuild for my application.
2. is the corvette servo worth the cost? Will I notice a difference in a jeep towing a boat or is this just going to give me whiplash when I get on the throttle?
Old 01-19-2010, 05:08 PM
SSedan64's Avatar
I'm not a Pro builder but, this doesn't sound like a Trans that is gonna be babied. Those 4L65E 5 Pinion planetaries aren't cheap,$350-$450. Corvette Servo isn't worth $50, maybe $10. It wont snap your neck, just firm up shift.
Most don't like the Alto 3-4 Power Pack = Thin steels. Z-Pack may be better choice. All in all, I'd upgrade as much as I could afford. Add Beast Sun Shell to the list $45.
Old 01-20-2010, 07:33 AM
Wac Wac is offline
Thanks for the advice
The BEAST is going in... now (it wasn't on the original parts list but several places I read, including your post, suggested it as simple yet strong upgrade)
Z-pack is already on the parts list...
Anything else? I haven't quite drained all the cash out of the Kids college funds yet....
Old 01-20-2010, 10:04 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
What are you doing about the TC?
http://racetransmissions.com/store/i...cPath/21_32_52
http://racetransmissions.com/store/p...roducts_id/418
http://racetransmissions.com/store/p...roducts_id/419
http://racetransmissions.com/store/p...roducts_id/692
Old 01-20-2010, 10:28 AM
n_keiser_rat's Avatar
its homemade, and its cheap!!!
as heavy as that trailer is you should run an extra or bigger tranny cooler, the 700r4 are good trans just make sure you keep it cool, they are notorious for over heating while under a heavy load. even if you dont pull the trailer all the time its a good idea and wont do anything but help you in the long run
Old 01-20-2010, 03:33 PM
SSedan64's Avatar
As Keiser Rat suggested run a (Large) external cooler and keep the cooler in radiator.
Also read this by Crosley on modifying the Lube to planetaries>> Increase lube oil to 700r4/4l60 rear planets ? the 5-Pinion planets have upgrades for lube, oil circuit that sends fluid to them can be modded.
Old 01-21-2010, 10:14 PM
Wac Wac is offline
I used to have this one:
http://www.bmracing.com/SPECIALS/Pol...11x4-1-2x1-1-2
but just ordered this one!
http://www.bmracing.com/SPECIALS/Pol...BTU-11x8x1-1-2
should be good right?? almost 3 times the BTU capacity... If I go much bigger my radiator might get jealous....
Old 01-22-2010, 04:46 AM
BigDawgsEatFirst's Avatar
400SBC4Life
What type of Warranty Offered????
Everyone is on track with answered given
Heat is Bad,Swimming is Expensive too
What type of Warranty is on the table???
Old 01-22-2010, 07:08 AM
Wac Wac is offline
Minimal... this shop builds for large trucks and other off road rigs... they don't do much for warranty on these because of the nature of the use of the vehicle. (Jeep: 4 wheeling in muddy Florida...original cause for the re-build) Other shops had similar policies. They stand behind the rebuild... but won't stand behind a trans that goes swimming routinely.
With that said... a good friend of my handles their business/shop insurance so the treatment has already been stellar. I'm not worried about getting the cold shoulder if I have a concern in the near future.
Old 01-22-2010, 07:34 AM
400SBC4Life
Good Deal
Have a Good Time with it
Youll like the Corvette Servo
Not Harsh At All
Old 02-09-2010, 08:40 PM
Wac Wac is offline
Not Harsh At All
Like it... I LOVE IT!! The trans after the rebuild is better than i thought it would be! Worth the extra bucks for the good parts... and the good shop.
Time for 700r4 rebuild? ohnny Transmission - Rearend 11 06-03-2007 08:14 PM
Rebuilt 700R4 does not function DoodleRay Transmission - Rearend 4 05-08-2007 07:18 PM
1991 700R4 binding in reverse after rebuild syclone477 Transmission - Rearend 15 08-24-2004 02:17 PM
Ford's Super Heavy Duty Transmission Capacity sum87mustang Transmission - Rearend 1 04-12-2003 03:33 PM
heavy duty t5 & a 383??? solowookie Transmission - Rearend 4 11-19-2002 09:12 AM
