700r4 Rebuild Info - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2006, 06:41 PM
700r4 Rebuild Info
i have a 87' 700r4 that i am going to rebuild. is their a video with easy to follow steps or a manual. i have torn down the trans and their was no signs of damage. also what must have tools do i need to have for example i was told a seal installer is a must and i can see why. is their anything on the internet i can download? thanks
Old 12-02-2006, 07:03 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
I have this Haynes manuel and successfully rebuilt a TH350 using it.
http://www.amazon.ca/Haynes-General-.../dp/1563921693
The Following User Says Thank You to 123pugsy For This Useful Post:
Robert broad (08-02-2012)
Old 12-03-2006, 12:40 PM
i have that one already. i was hoping there was a video or a manual specific to 700r4's like maybe a factory manual. the haynes manual is ok and afer i reviewed it i still had to refer to a local tech and glad i did because i would have been wasting my time and money on the parts i have already purchased. glad you were successfull in your transmission overhaul thanks.
Old 12-03-2006, 12:47 PM
DeathRattle's Avatar
Some Punk Kid
http://www.technicalvideos.com/video...smission.phtml
That should do it. 30$ is steep though.
Old 12-03-2006, 10:29 PM
BigDawgsEatFirst's Avatar
400SBC4Life
[QUOTE=DeathRattle]http://www.technicalvideos.com/video...smission.phtml
I have that video and Paul tells u enough to break it all down and put it together again.
Alot of info is left out of the video.
I went to the area shops. That is the Meat and Potatoes to find info. Take your cleaned parts. Do not be afraid to ask them to help you
Actual guys that know what work.
You are in the right place here + ATSG book,Video,and local trans shop help.
ONe more thing
Clearances,Clearances,Clearances
700R4 Low Pressure Problem 31rdster Transmission - Rearend 8 11-26-2004 08:43 AM
700R4 Info trees Transmission - Rearend 4 08-06-2004 06:24 PM
85' 700r4 info GoneNova/406 Transmission - Rearend 4 08-06-2004 12:56 AM
Holley Rebuild cub Hotrodding Basics 11 06-23-2004 02:23 PM
windsor info Blag Engine 1 04-24-2003 08:08 PM
