700r4 rebuild issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2012, 02:53 PM
Hello all,
I recently went through a 700 r4 and replaced all the clutches and steels and band. Everything was in good shape except for some burned clutches. Put it back together and am having a problem with up shifting. I remove the tv cable at the throttle body and it will stack shift I think I hits all the gears, I'd have to check again.
One thing I notice is the tv cable snaps easily when the truck is off, but I can barly actuate it with he truck running. I bought a gauge set and the pressure sits at 120 in park at idle. Any ideas about what could cause that tv cane to not snap back when the engine is running?
Thanks for any help
Old 10-19-2012, 09:46 PM
i had a 700r4 rebuilt and had alot of up shifting issues and it going in and out of over drive it turnd out to be the valve was sticking in the valve body hope this helps.
Old 10-22-2012, 01:57 AM
SSedan64's Avatar
That pressure is too high for idle, should be about 1/2 that. Pressure Regulator valve or TV Boost valve may be stuck/binding. TV plunger etc..
2002 4L60E rebuild with some issues...... Sierra02 Transmission - Rearend 8 12-21-2011 02:39 PM
My first rebuild SBC 350 Centerbolt slight issues monette999 Engine 8 06-30-2011 10:04 AM
Update to SBC rebuild and oil pressure issues Gun Laker Engine 0 12-02-2009 06:33 PM
Holley Rebuild Issues zildjian4life218 Engine 15 10-24-2009 01:51 PM
700R4 issues hansens83customdelux Transmission - Rearend 2 07-25-2009 11:56 PM
