700r4 rebuild question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2011, 07:33 PM
So I am a Mechanic by trade have been for last 14 yrs but in Honda world . So anyway I have rebuilt a trans along time ago so anyways, I got it all together only reason I tore down was the typical 3-4 clutch failure . It makes a weird light screech in forward clutches I was boggled so I tore it all apart it all looks correct to how I tore down and by GM SM I have for it. I narrowed down noise to be in the forward clutches end case tailshaft plantary gear.
It is it common for the clutches to make a light noise by hand turning input shaft in engine rotation ? I soaked clutches in dex synthetic fluid . I just don't want to put this back in to have a horrible issue , I may just be parnoid I check torrenton bearings the are in correct postion not flipped or what not
Old 09-20-2011, 09:11 PM
Overdriv's Avatar
I think what you are hearing is the sprags dragging one way and quiet, locked, the other, right? It's not a problem, you won't hear it when full of oil and running.
Another 700r4 rebuild question. drives in N Grogetter Transmission - Rearend 12 08-22-2011 12:22 PM
700R4 rebuild kit fierosum Transmission - Rearend 6 08-28-2010 11:04 AM
700R4 out of an 84 K5 .... first rebuild junkbike Transmission - Rearend 6 03-23-2009 10:45 AM
700R4 rebuild fivewindowcoupe Transmission - Rearend 3 01-26-2009 08:46 PM
700R4 Rebuild StudebakerBob Transmission - Rearend 21 11-09-2004 11:04 PM
