Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 rebuild with wider low reverse roller clutch
Old 01-02-2010, 10:25 AM
qwkswede qwkswede is offline
It is definitely a corvette case. Thats fine with me, it is going into a volvo with a fabricated cross member. I can work with the vette style mounts. I would have preferred that tje trans was untouched and original for my first rebuild. I dont really need unexpected combos to confuse me right now. I wonder what wierd mix match parts i will find. Since it seems that someone retrofitted the th350 roller clutch assembly i assume they are interchangeable? I want the stronger one. I will do some calling to see about buying the later style carrier.
