Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 rebuild with wider low reverse roller clutch
Old 01-02-2010, 11:56 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
I've seen many late cores with early parts inside.
the center support for the wide roller clutch will fit back in place.. you MUST watch the low-reverse clutch pack clearance.
the late design low - reverse clutch pack uses a waved plate then 5 flat steels and frictions..
there was also a thicker flat plate with 4 standard flat steel plates used with the waved cushion plate.
