Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 rebuild with wider low reverse roller clutch
Old 01-03-2010, 05:00 AM
123pugsy's Avatar
123pugsy 123pugsy is online now
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Like Crosley mentioned, check your clutch pack clearance.
The manual will tell you to measure the stack up and such but I found a nice tip online somewhere whereby you can use some pennys or dimes on top of the clutch pack and drop in the center support to check the clearance.
I usually do this before installing the reaction gear and carrier.
