Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 rebuild with wider low reverse roller clutch
Old 01-03-2010, 11:23 AM
qwkswede qwkswede is offline
OK, there are a couple things that the ATSG guide seems to skip.
I have a dimension for the stack height of 1.200 - 1.240". But I don't see a clearance spec in the ATSG manual. Penny thickness looks to be about .060-.065". Is that about right?
Also, is soaking the frictions in ATF before assembly the recommended treatment?
And one more Q. Vaseline is appropriate for assembly lube on the bearings, bushings, and rubber parts?
