700r4 rebuilt but noisey shifts - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2008, 08:38 AM
I have an 84 camaro that has the 700r4 in it. I lost the 3-4 cluth packs So I had it rebuilt. The man at the shop used parts from another 700r4 to update the transmission. Went with the 30 spline input shaft and he made the other changes for everything it fit. Modified the valve body for firmer shifts. I have come to notice that when the transmission down shifts when I am just coasting there is a "Clank" noise with the shift. I have check to make sure nothing was rattling and have some to believe its the transmission. It seems to drive just fine the olnly other Issue I have is the TCC Solenoid is no good. I have tested it and the coil is shot. I have since moved about 12 hours from the shop the work was done. It is no big deal to me to change the TCC since I have a new one but the noise is my only concern. Any ideas of what it is would be great.
Thanks
Old 08-25-2008, 08:37 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks
I would check the mounts , drive shaft , U-joints , if you have not.
When this happens , is the shifter in "OD" or "D" ?
Old 08-25-2008, 08:59 PM
Mounts and everything looks good.
I only seem to notice it in OD when it down shifts when I am coasting and slowing down.
rebuilt 700R4 shifts at 4000 RPM chris/toyota Transmission - Rearend 7 01-08-2008 06:45 PM
700R4 Late shifts yesgo Transmission - Rearend 12 05-06-2007 03:27 PM
SRTA (700R4) shifts late % Too hard PLWC Transmission - Rearend 1 02-15-2007 05:20 PM
1989 4l60( 700r4) shifts from 2nd to neutral Riby Transmission - Rearend 10 04-07-2006 12:51 AM
700R4 Shifts Keppie Transmission - Rearend 6 07-16-2002 11:48 PM
