Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 removal advice.
Old 07-28-2003, 10:10 PM
mr.chevelle's Avatar
mr.chevelle mr.chevelle is offline
Yey you will have to loosen the drive shaft from the rearend.Once you get it loose it will slide back toward the rear of the car about 3 inches and come out of the trans.Ive never worked on the camaros but i asume that it is the same ive never seen any no diffrent.Also this is the prefect chance to replace your U joints.They are cheap so you mide as well do it know.
