700r4 retrofitting - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2005, 11:08 AM
flaming79's Avatar
Run it if you build it !!
Last journal entry: Almost ready to go cruzn
700r4 retrofitting
Ok,, I put in the 700r4 finally, I bought it off e-bay so I'm not really sure on what it is exactly. The guy claimed it had a 2800 stall but I'm leaning more to 2400 but I will get to that later. My question is in the Lock up part of the tranny. I was told it has a lock-up converter, I bought the switch from TCI that I believe goes to it, Guess it plugs into the plastic plug on the top of the tranny. Will it hurt the tranny if I don't hook this up. The tranny was supposable built by a tranny shop called weber transmission in Texas. Had some upgrades done to it to withstand 500+ HP. I love the tranny, I just don't want to mess it up by driving it without that hooked up. Any info would be great.. Thanks,,
flaming79
Old 10-30-2005, 02:09 PM
BigDawgsEatFirst's Avatar
400SBC4Life
If u have a lock up converter
yes,It needs to be hooked up and working
dont keep driving without it
and proper t.v. cable adustment is very,very......Important
I have a vaccum switch on mine
I can feel it lock on the highway
I just gave you ,my opinion
Crosley is the trans expert on this forum
Old 10-30-2005, 02:17 PM
flaming79's Avatar
Kickdown cable
I have the Kickdown cable on and adjusted right, as the instruction showed. I was told that one or 2 trips around the block will burn up the tranny with it not hooked up, cuz it determines the fluid pressure in the tranny. Any idea y it is bad to run it with no wiring for the torque converter lock up, and can I just get a none lock up converter or are they matched with particular trannys that lock up? thanks..
flaming79
Old 10-30-2005, 02:26 PM
400SBC4Life
thats good you know about the throttle valve already
kits are everywhere to use the lockup if u want to
like this http://shop.store.yahoo.com/performa...70locswit.html Its pretty straight forward to install.
Old 10-30-2005, 02:38 PM
flaming79's Avatar
Will I be OK driving it without it hooked up periodiclly till I do get wired in. What are the pros of having a lock up, I noticed they are alot more pricy
then none. Do they just stop the stall from slipping on the highway?
Thanks,,
flaming79
Old 10-30-2005, 04:05 PM
Ricky Rocket's Avatar
Drive it like a rental!
700-r4
The purpose of the torque converter lock-up is to get a 1:1 ratio out of the converter at highway speeds. This eliminates the slippage that is part of a non lock-up converter. This lowers your cruising RPM and keeps your trans a little cooler. If you do any highway driving, it should be hooked up and working.
Rick
Old 10-30-2005, 04:29 PM
place on ebay, oregon performance transmissions, has lock up torque stall converters fairly cheap. might check them out.
Old 10-30-2005, 05:38 PM
flaming79's Avatar
converter lock up kit
Does that converter lock up kit that the link brings me to, hook up to the factory conector on the tranny? http://shop.store.yahoo.com/performa...70locswit.html I don't see a plug for it. I'm probly going to get it. I have the TCI one that runs off the vac, but you have to pull the pan off and run new wires in the tranny,(would rather get away from that if possible) if anybody is interested in it. I will give you all first dibs. I paid 80 bucks for the kit. I can e-mail pictures if anybody would like.
flaming79
Old 10-31-2005, 09:33 PM
flaming79's Avatar
Guess I have no takers?
Old 11-13-2005, 10:23 AM
fl_rider's Avatar
Here is a site I found
I hope this helps:
http://www.smokemup.com/tech/700r4.php
Chris B
Old 11-13-2005, 11:46 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the posted link to the Yahoo store kit...... that kit will not fit a late 1989 to 1992 700 / 4L60 tranny easily.
The kit is designed for external use as it appears to me. The pressure ports on the passenger side of the 700 / 4L60 case were eliminated in 1989. You would need to drill the servo cover and tap it for the pressure switch in the Yahoo kit.
OR remove the tranny pan and work inside it.
700r4 tranny in 2nd gen 1980 camaro !HELP! william27103 Transmission - Rearend 10 11-02-2005 06:53 AM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 03:34 AM
700r4 stock stall? Caesar_Mikey Transmission - Rearend 1 03-27-2005 05:52 PM
4x4 700R4 to 350 swap Davesblazer87 Transmission - Rearend 4 12-22-2003 07:59 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
