700r4 reverse slippage - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2013, 06:44 PM
I recently put in a 700r4 in a 66 Pontiac w/ a chevy 454.I was told the trans was somewhat fresh so I threw it in w/ a shift kit.I haven't driven it but so far it goes forward no prob.But it slips bad in reverse.Now,did I do something wrong,or did I end up w a P.O.S.?I have rebuilt a few th350s but Im trying not to do this one,Any tricks or experiments I could try?I was told to try driving it around a little and then trying it but that sounds kinda dangerous on the trans if its some thing traumatic.Ive never had to drive it around or warm it up to get a trans to grab that wasn't already junk.Should I maybe drive it to see if I have all my forward gears?Im a little nervous about doing that w the reverse not grabbing.I really wish I would've tried it before putting in the kit!Any help would help this cruz ship do 11"s! thanx a lot folks..Woody
Old 10-28-2013, 10:21 PM
Late reader of your post. It seems a lot of the 700 had this problem. No expert on the 700. Did you drop the pan and see what it was like inside before you put it in. Have you got the TV CABLE set up right? You've got to put a tranny gauge on it to see what your pressures are and that will tell you a lot about each gear including reverse.
Old 10-29-2013, 06:43 PM
Atually I found it.I dropped the pan and found the booster valve fell out.Thasnap ring wasn't in right.Works great now.Thanks tho.
Old 10-29-2013, 06:53 PM
Put the gauges on it and see what kind of pressures you have and make sure, there up to the task.
700r4 converter slippage kansan Transmission - Rearend 6 03-26-2012 11:41 PM
700r4 reverse bebopwally Transmission - Rearend 1 08-18-2009 09:41 AM
No reverse gear and slippage in Drive 2nd gear. jadejoky28 Transmission - Rearend 14 04-09-2009 12:49 PM
700r4 reverse xlubeguy Transmission - Rearend 3 12-20-2006 12:03 PM
700r4 no reverse bwood Transmission - Rearend 2 11-21-2004 07:26 PM
