I have an 85' GMC Suburban 1/2 ton 4x4 with the 700R4 trans (3.42 gears).
It has the 3-wire TCC lock-up arrangement and I am trying to validate the operation of the converter clutch.
The only thing I can tell is that when I unplug the TCC connector at the trans, the RPMs at any given speed in 3rd or 4th gear is about 150-250 RPM higher than when the plug is installed.
Does this sound about right?
For some reason I was expecting something a little more dramatic.
The trans shifts fine otherwise- I just can't tell (even with the tach) when the trans goes into or out of lock-up.
I verified all the wiring and the solenoid is getting 12 volts (I can hear it click when I apply 12 volts and the engine off).
I guess I just need a sanity check before I go tow the kids back to college next week and cook my trans. I think I'm OK but would like some confirmation.
Thanks!
Elm
From what research I've done is that 4-prong/3-wire conncetor runs the lock-up. So no plug, no torque converter lock-up. That's the theory I'm working with on my truck...doens't mean it's right.
Well what if the trans goes though all 4 gears OK...but when the torque converter is told to lock up(I ran a manual lock-up toggle switch into the cab) in 4th gear, and i know it's locking up...but the RPM's don't drop...does that tell me my torque converter is trash?
Thanks!
Elm
I give a second nod to the solenoid if you think it is wired correctly. I had on 200-4r rebuilt, and scratched my head for a week trying to find what I wired wrong putting it in. I had to drop the pan and swap the solenoid, and that did the trick. I had all 4 gears right, but no lockup in 4th until i swapped.
Took the truck down the road one day and lock-up suddenly hit in 4th gear...completely out of the blue, have been running it since and it's running alright. Dropped my number 5 cylinder though, no copmpression so now I'm getting the money to rebuild the engine. If it's not one thing, it's another. Thanks for your help guys. But I think you were right, something was off with the solenoid.
Status
Not open for further replies.
You have insufficient privileges to reply here.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
