700r4 in an S10, what crossmember??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2008, 11:49 PM
Plum Nasty's Avatar
Here To Learn From The Best!
I'm putting in a 350 in an 83 S10 and I'm going to back it up with a 7004r trans. Who all has done this and where did you get your crossmember? I'm thinking I'm going to have to do the same thing that I had to do on a 64 Impala and just cut and fabricate it. If so, some pics of what you did would be great. If you would like to see what I'm starting out with, you can check out the pics in my introduction thread here
Old 08-29-2008, 12:06 AM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
The V8 S10 my son & I did used the stock trans x-member in the stock place. In the kit we got it had a spacer to lift the rear of the trans up about 1/2" to 1"
Old 08-29-2008, 12:10 AM
SSedan64's Avatar
http://transmissioncenter.net/700R4_Swap_Info.htm
http://www.transmissioncenter.net/700r4.htm
Old 08-29-2008, 12:16 AM
Plum Nasty's Avatar
That is exactly what I have been looking for. Thank you guys.
I have a 48 chevy sedan Has anyone installed a 91 mustang 5.0 crossmember or any tips jokr8 Suspension - Brakes - Steering 3 06-19-2008 06:04 AM
Putting a 1987 700R4 in my 1982 GMC 4x4... indy_85stariones Transmission - Rearend 12 04-28-2007 03:04 PM
S10 700R4 to 76 Blazer swap Drewnashty Transmission - Rearend 6 06-12-2006 10:30 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 07:44 PM
Review of FatMan IFS Airbag install 1938 Chevy PU Grashopr Suspension - Brakes - Steering 3 08-26-2003 12:16 AM
