700r4 servo question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2011, 05:34 PM
My 700r4 seems to be slipping a bit on full throttle application when in Drive... 1, 2nd, 3rd, seems to hold fine when manually shifting...would a larger servo help out?.. been driving it nice since i started to notice it happening... tv cable tightened up a bit but now I have firm shifts and pull out of that adjustment at wot....I'm guessing I'll probably need a tranny soon but was hoping a servo would "patch" problem for now..any thoughts...
Old 06-01-2011, 06:35 PM
The servo only applies the band for 2nd, & 4th.. If it is slipping in any gear other than 2nd, or 4th, then no servo on the planet is going to help.
If the trans has had a hard life-it is probably time for an over-haul. Once they start slipping, they don't last much longer after that.
Here's another idea that I think you already hit on-don't drive it under full throttle at least until you have the dough to shell out for a new transmission.
700R4 adjustable servo south65ss Transmission - Rearend 3 05-16-2009 07:41 AM
700r4 Servo Install won't fit oldchevy1956 Transmission - Rearend 4 04-28-2008 02:43 PM
700r4 4th gera servo problems fivewindowcoupe Transmission - Rearend 1 06-24-2007 04:36 PM
Changing Servo on 700R4 KeithB123 Transmission - Rearend 4 01-26-2005 09:09 PM
700r4 servo question chevcamz28newbie Transmission - Rearend 4 08-08-2003 12:53 AM
