700r4 shift 2nd-3rd slip/rev - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2006, 06:44 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
First off my tranny is freshly rebuilt about 6 months ago.I've only drove it about 20 miles.When it shifts from 2nd to 3rd it revs/slips a bit.Fluid level is dead on.TV cable is a little bit loose at idle.I loosened it to achieve WOT.The Edelbrock carb (600 cfm) throttle center to where the tv hooks up dimension looks a little large compared to geometry info I have read.I have a TCI OD lockup kit installed. Any thoughts? Thanks.
Old 04-24-2006, 10:06 PM
Jmark's Avatar
(sitting here in fear and trembling of making the wrong suggestion, I'll offer this.)
The Edelbrock and Holley carbs do not have the correct linkage hookups to achieve the proper TV cable setup. There are add-on linkage adaptors that you need to correct the TV geometry on those 2 carbs. I"d suggest that you not drive it like it is until you verify that the cable pull is correct.
Mark
Old 04-25-2006, 09:19 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
MAny things can cause a RPM flair during the 2-3 shift in a 700.
Low pressure from a misadjusted TV cable.
Incorrect 3-4 clutch pack clearance.
Too much power for the 3-4 clutch pack installed.
A pressure leak in the drum or related part of the 3-4 fluid circuit.
700R4 will not shift into 3rd and 4th gear bebopwally Transmission - Rearend 14 05-25-2006 07:48 PM
700R4 2nd gear start/4th gear bind up? myclone1 Transmission - Rearend 3 04-19-2005 02:51 PM
700r4 wont shift into 3rd BIG DIXIE Transmission - Rearend 1 01-12-2005 07:04 PM
700r4 won't shift into 3rd????? HELP!!!! ConvertablePickupGuy Transmission - Rearend 7 02-14-2004 05:44 AM
700r4 shift problem,1st to 2nd root Transmission - Rearend 2 10-19-2003 11:31 AM
