700r4 shift issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2009, 11:59 AM
700r4 shift issue
I have an 84 chevy c20 with a 350 and a 700r4 tranny in it. It came stock with a quadrajet carb. I just put an Edelbrock carb on it and now it wont shift out of first gear. I started having this issue before I swapped carbs. It wouldn't shift until about 30 mph which was about 3500 rpm. Now that I have swapped carbs it wont shift at all. Any Ideas?
Old 01-28-2009, 06:12 PM
302 Z28's Avatar
You may have other transmission issues since you stated this was going on before you swapped carbs. It is imperative that you have the proper TV cable geometry for the 700R4 to operate properly. The Edelbrock carb must have the right TV bracketry.
Prolonged driving with an improperly configured TV cable can kill your transmission.
Vince
Old 01-28-2009, 10:43 PM
SSedan64's Avatar
Vince is right, You'll need one of these plus adjust the TV cable, hope the trans hasn't suffered any damage.
http://cgi.ebay.com/ebaymotors/700R4...5551QQtcZphoto
http://purplesagetradingpost.com/sum...o/700R4p1.html
Old 01-29-2009, 09:02 AM
runn141's Avatar
i know nothing about the 700r4, yet. but when i go to rebuild me one im gonna be using one of these.
http://www.compperformancegroupstore...ct_Code=376020
Old 01-29-2009, 10:13 AM
SSedan64's Avatar
You'll get to enjoy constant hard/firm shifts at all throttle positions & early pump & seal wear also.
Old 01-29-2009, 03:01 PM
runn141's Avatar
will it hurt to have it adjusted tighter than from factory? i remember reading on here that someone said they ran the cable tight as possible?
Old 01-29-2009, 05:29 PM
SSedan64's Avatar
A click or 2 in either direction can be used to fine tune shift points. If you have it too tight the trans may not shift or shift at very high rpm. Tighter increases pressure, loose lowers pressure=not good. Here's a good tutorial on setting the TV cable & what is actually does.Part I, II & III.>>>>>
http://www.tvmadeez.com/article/index.php
Old 02-02-2009, 12:24 PM
Thanks for the advice. This is the first swap I have done with the 700r4. I knew I was forgetting something. Still has the issue of shifting late so that is something else I have to figure out.
thanks again
Old 02-02-2009, 01:50 PM
i highly suggest these guys kits
700r4 shift / tv question mican99 Transmission - Rearend 3 05-04-2009 09:08 PM
700R4 doesn't shift right...... flashback Transmission - Rearend 5 07-06-2008 11:41 PM
700r4 shift problems radrobnc Transmission - Rearend 11 04-04-2008 03:14 PM
700r4 wont shift into 3rd BIG DIXIE Transmission - Rearend 1 01-12-2005 07:04 PM
c10 - th350 to 700r4 swap column shift 70chevyc10 Transmission - Rearend 7 10-25-2004 09:35 AM
