700R4 shift points - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2005, 06:37 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
700R4 shift points
I have checked the archives and found similar problems, but not quite the same. 1-2 shift occurs @4100, 2-3 shift occurs @5200. How can I have the shift points be comparable? The trans is a rebuilt 700 with a tranny builders shift kit. I am running a 2600 Stall and a 3:89 rear.
Thanks,
Bob
Old 04-17-2005, 11:05 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
on the governor there are two different springs..... light tension / heavy tension.
the weight on the heavy spring side....... gring a 1/4 inch wide and deep notch in it. See if this helps.
A slightly softer spring in place of the stiffer spring will cause later light throttle shifts , sometimes will delay WOT shift point slightly too.
Does this tranny upshift to 2nd gear while the shifter is in "1st gear" ??
Old 04-17-2005, 12:24 PM
AngliaBob's Avatar
Crosley,
I don't know if it will shift to 2nd if held in 1st. I will try to do a test drive, and check it out. The trans is an 85. The car weighs 2500lbs or so.
When you said 'gring a 1/4 inch wide and deep notch in it. See if this helps.'
Did you mean grind?
Old 04-20-2005, 11:00 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
yes grind. speeling is not my strong point, that and the fact that i cannot type
If it is an 85 unit , it will upshift from 1st to 2nd with the shifter in "1"
Originally Posted by AngliaBob
Crosley,
Did you mean grind?
setting points on sb chevy frackster66 Electrical 23 01-07-2014 05:50 PM
700r4 won't shift at WOT Alex99 Transmission - Rearend 39 02-15-2005 09:08 PM
700R4 Shift Points ARPEE Transmission - Rearend 8 07-19-2003 11:16 PM
700r4 shifts in and out at shift points? dpjmw Transmission - Rearend 11 03-30-2003 12:32 PM
C-4 shift points 5.0 Fury Transmission - Rearend 1 07-30-2002 11:48 AM
