Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 Shift problem?
Old 03-24-2012, 06:34 PM
Prof. T. Soggmeyer's Avatar
Prof. T. Soggmeyer Prof. T. Soggmeyer is offline
Plan B
You need to change the geometry of where it attaches to to carb. I simply made an arm and positioned it so it traveled the correct distance. The farther from the pivot you go with the cable hook-up,the more it will pull the cable. I will post a pic of mine if you'd like.
