700r4 shift problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2010, 10:01 PM
chewyscool's Avatar
Big Block 454
Crosley, would your advice be the same if the tranny shifted fine through all gears at part throttle, but at WOT will not shift out of 2nd unless the gas is let off........I dont mean to highjack but I'm have similar problems, I'm trying to plan before it comes out.
Old 02-23-2010, 06:37 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You are asking different question than the original thread you posted to, so I split off this question to a new thread.
The other post was about the 2-3 shift the engine would rev up as if the trans was in neutral. Your situation as described is a no shift to 3rd gear at high RPM.
How high RPM is your engine rev'd to?
Reduce the pull on the TV cable at WOT to see if that helps.
Usual cause of the no upshift you describe is pressure loss in various areas of the trans . The pressure does not build high enough to move the shift valve. A worn TV bore in the valve body, worn governor bore, check the governor weights.
TransGo also believes at high RPM ( over 6500) the check ball in the aluminum drum will not seat in the capsule and simply blows off oil pressure. So there is no 3rd gear shift.
TransGo provides a steel insert to replace the check ball capsule in the aluminum drum 3rd gear piston area. It has a small bleed hole in this insert. My opinion is the hole is too large, so I peen this hole down if I use this capsule which is seldom.
Old 02-23-2010, 08:57 AM
sqzbox's Avatar
My pipes are my music
I'd look real close at the Governor. I had shift problems and with close inspection with a set of calipers, was amazed at how little wear (.007-.009) on the shaft caused my problem after putting in a new one. The gear and the weights were still in good shape on the old one.
My problem was tranny falling out of 3rd gear at hwy speeds (over 50mph) and would not up-shift back to third unless you stopped and started again and some times that wouldn't even work.
Old 02-23-2010, 07:06 PM
chewyscool's Avatar
Big Block 454
Thanks for the replies, here is the Wot approx shift points as per my tach:
1st will shift to 2nd 4500
2nd will hold all the way up to 5500 and not release
my cam is all out @ 5200 so i rarely rev higher than that.
Agian this is all at wot.
Shifting normal cruising around town.
I have set the Tv many times in many different positions from all out to almost all in and in between as well. I will pull the pan and check the gov as well. I not really sure what to look for other than thrash in the pan. Would anybody recomend or used the DVD's for BOXWRENCH.com? I been thinking bout getting the 700r4 rebuild vid, just for knoledge.
